Great fun reading the forums!
Started buying B&O stuff back in the 80ies and by now my house is "well equipped" (my wife would use more profane words)....  But, I have really never been able to crack the Link Option logic, given that there is one ;-)
Anyway, in this case I have
- a BeoSystem3 [v.opt 2] in the main room
- one room with a BeoPort [opt 6] and a BeoMaster 7000 [opt 0] hooked up through a 1611 ML/MCL converter
- a second link room with a BeoLink Active [opt 6?].
Please also see the sketch below. "All" I want is to be able to habe the full link functionality in all rooms: N.RADIO, N.MUSIC, TV, RADIO, PHONO, etc.
The challenge is that the BeoPort and the BM7000 fight each other. When the BeoPort is removed basic commands work well in all rooms, obviously excluding N.RADIO and N.MUSIC. If I instead remove the BM7000 I can use the BeoPort extended command set incl N.RADIO & N.MUSIC, but then obviously the BM7000 functionality RADIO, CD, PHONO, etc. will not be available.
When I have both the BeoPort and the BM7000 hooked up the N.RADIO command from any room turns on PHONO on the BM7000 (together with N.RADIO on the BeoPort if I'm lucky). The N.MUSIC command turns on TAPE2 on the BM7000.
 Any combination of link options that would make this work?
Any other workaround other than junking the BeoPort and instead drive an AUX port on the BM7000 directly from the PC? My wife will not let me buy the BS9000 that I think I deserve after all this ;-D
Thanks! / Ulf
