Well.. It's a rather large room and the 4-50/BS3 is in one end and the BS9000 is in the other end. The ML-socket is in the "middle". I would simply preferr to have a dual socket on the wall and then one, molded/crimped ML-cable in each direction, rather than some visible "connections" that splits up the cable coming out of the wall into two cables (which ofcourse could be done..). As with all B&O issues - it's all about
esthetic.. If it's not installed properly (with cables hidden in the walls etc.) half the point with B&O goes missing in my (humble) oppinion...
