Latest post 06-06-2007 3:07 AM by Roger. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • 06-05-2007 8:31 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: Poor picture quality DVD player BV7
    One could argue if there is a difference between ON and AUTO. When watching a DVD the Film Mode would be on always, but by selecting AUTO you could avoid activating it while watching a football match recorded on a DVD. AUTO will try to detect if the material is a movie or not.
    Roger
  • 06-05-2007 3:27 PM In reply to
    • Mike
    • Not Ranked
    • Joined on 04-16-2007
    • Germany
    • Posts 20
    Hi Roger,
    do you know if the AUTO mode tries to detect a film only once when a source is selected (when switching tv channels or starting a DVD), or is it done continuously?
    If the latter is true, there might be a chance that the film mode is activated inadvertently, for example when someone watches a sports event. In that case I think it is best to either set the mode to ON or OFF.
    Michael
  • 06-06-2007 3:07 AM In reply to
    • Roger
    • Norway
    • Posts 870
    Hi Michael,
    I do not know exactly how smart this feature is. But it is not entirely true, as stated in an earlier post, that film mode doesn't do anything to improve the end result: It will make sure that details of a moving object appear clearer (compared to "sport/regular mode", where the texture of a ball is not as important as a fluid movement) - the side effect is the well-known ripple effect between the moving object and the background.
    Roger
