Latest post 06-06-2007 3:07 AM by Roger. 27 replies.
Page 1 of 2 (28 items) 1 2 Next >
  • 05-11-2007 2:16 PM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Poor picture quality DVD player BV7
    Does anyone have any comment on / shares the same experience as mr. Kasper Wedendahl:
    http://www.bang-olufsen.com/Community/forums/thread-view.asp?catlock=1&tid=5073 ?!
    Filed under:
  • 05-11-2007 2:47 PM In reply to
    Re: Poor picture quality DVD player BV7
    Surprised B&O have left that one up! I know some people don't like Film Mode. Always been very happy with it on my Avant DVD.
  • 05-11-2007 3:17 PM In reply to
    • Doc
    • Posts 585
    What does the Film Mode mean (I don't own a B&O tv) ?
  • 05-11-2007 3:29 PM In reply to
    Avant DVD is a good tv though :-), no other current B&O tv compares to it in every respect IMO Cool
  • 05-11-2007 3:33 PM In reply to
    Film Mode is an extra piece of Digital trickery to make movement more natural. Some people like it, some don't!
  • 05-11-2007 3:42 PM In reply to
    • Doc
    • Posts 585
    So you can choose to watch in this Film Mode, or in another? You don't necessarily have to shut it off via the system mode (as mentioned by Kasper Wedendahl) ?
  • 05-11-2007 4:00 PM In reply to
    No. You do need to go into the service menu.
  • 05-11-2007 4:06 PM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    As Peter said; there's nothing wrong with the DVD player - the Film Mode will add effects that I do not like either, and it is a B&O TV thing. In fact, the Film Mode is reason enough to upgrade to the BeoSystem 3 for some.
    Roger
  • 05-11-2007 4:11 PM In reply to
    • Doc
    • Posts 585
    Pretty expensive upgrade; say goodbye to the BV7 and buy another BV in combination with BS3?!
  • 05-11-2007 4:16 PM In reply to
    Mr. Wedendahl speaks with some authority. He's an established Danish film director ... wonder whether something was wrong with his set?
  • 05-13-2007 3:14 PM In reply to
    • Roger
    • Norway
    • Posts 870
    I do not belive there was something wrong with his set. B&O haven't spent as much time on Film Mode as they should have, a slightly altered Philips invention that is okay on a cheap tv - not on something like the BV7. The BeoSystem 3 sorts this out in an excellent way, but you will have to find room for a big (50") screen. And the comment regarding HDMI - spot on. B&O will have to fast track the updated version to keep their sales up...
    The BeoVision 7 does a great job on anything but movies - turning Film Mode off solves one issue, but adds another...
    Roger
  • 05-14-2007 6:55 AM In reply to
    • Doc
    • Posts 585
    Roger,
    What do you mean when you say it adds another issue (if you turn film mode off) ?
    Marcel
  • 05-14-2007 10:06 AM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Peter:
    I know how to access the service menu, checked it for the "film mode", but I could not find it. I wanted to see what difference it makes. Could you tell in witch chapter I can find the film mode?
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-15-2007 2:57 PM In reply to
    • Roger
    • Norway
    • Posts 870
    Marcel,
    The Film Mode feature isn't all bad. It is a digital motion compensation for sharp motion reproduction, and does so in quite a few cases - but objects that move, especially while the camera is moving too, will get this funny outline that we all learned to dislike with the old Avant and the BeoVision 3.
    Roger
  • 05-16-2007 2:08 PM In reply to
    • Doc
    • Posts 585
    Do you get the funny outline with or without FilmMode?
  • 05-16-2007 5:19 PM In reply to
    tom:
    Peter:
    Some old software do not offer this choice. My BV3 is v7.3, and I can't disable it. Hopefully I like it very much !
    Quoi de mieux qu'un BeoLab 2 ? 2 BeoLab 2 !
  • 05-23-2007 8:08 PM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    Roger,
       Just wanted to clarify.  I just bought a used Beosystem 1 and was planning on defeating the Filmmode for the same reasons as Mr. Wedendhal.  Are you saying, however, that by defeating Film Mode you reduce some quality aspects of the upconversion other than motion compensation?
    Michael
    Atlanta
    -Michael
  • 05-24-2007 4:59 AM In reply to
    • Roger
    • Norway
    • Posts 870
    Michael,
    Yes, the Film Mode function is meant to process moving pictures in a different way when watching a movie compared to, say, sports. But the good thing is that you can turn it on/off as you please - so just give it a try. Some prefer to leave it on (and it may be the best option, knowing the B&O viewing panel and their track record) and a selected few prefer to turn it off.
    There are scene's where I do feel that Film Mode can't cope: If the camera is moving to follow a moving actor against a rather detailed background. A recent example of the effect (comparing Film Mode with the uber-cool BeoSystem 3) is when watching Casino Royale.
    Roger
  • 05-24-2007 5:11 AM In reply to
    • moxxey
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Roger:
    Oh dear. This is the only (recent) movie when, for the first time in years, I turned on the Film Mode! I noticed a big difference from the start as, like you say, the camera follows the actors against a moving background. There appeared to be a shadow/effect around the actors. Result? Film Mode went off again, fairly quickly, and I've not tried it since!
  • 05-25-2007 12:33 AM In reply to
    Roger:
    Roger
     I do want to add the movie "House of Flying Daggers".
    The scenes in the bamboo forest made me sad, when I saw the ghost image during the scene.
    For test I did turned the movie mode OFF. Hope I can see a difference with the upcoming movies to watch.
    Filed under: ,
  • 05-25-2007 7:07 AM In reply to
    What disadvantages is there to put Film-mode Off?
     /Martin
    Beolab 5 with sw 3.0,  BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
  • 05-25-2007 10:10 AM In reply to
    • Philippe
    • Toulouse, France
    • Posts 321
    None... It's just a crappy stuff inherited from Philips (a brand well-known for their lousy picture treatments, such as Pixel Plus that makes any given film look like it was filmed as a live show).
    Philippe
  • 05-29-2007 1:53 AM In reply to
    film mode is weird , it creates a bizarre pixellated mess about anything that moves and also gives everything else a kind of queasy , stomach churning other worldliness quality that i find most disconcerting
    it's like watching everything while being high i imagine , not a pleasant experience i think
    eeeurgh
    popgear is grate™
  • 06-02-2007 6:14 AM In reply to
    • Doc
    • Posts 585
    Will the BS3 panel of the new BV7 be better?
    Marcel
  • 06-05-2007 8:19 AM In reply to
    Roger:
    Michael,
    Roger
    One question.
    In hidden menu: picture adjustments, feature box menu, movie mode
    the options are
    ON
    OFF
    AUTO
    Can you tell something more about the AUTO function?
