I have a Lutron-system with a wall-mounted keypad with a built-in IR-eye in one of my rooms at home. When I use the Beo 5 it is sometimes pretty hard to get the signal to the Lutron-system, I have to be pretty close.
Can the Beo 5 be set in some sort of "dealer mode" which gives a weaker IR-signal than normal ? I can recall that I have read something about some sort of dealermode somewhere on this site. If so, how do I change this ? Does anyone have any other suggestions or experiences ?
Best regards
Hans
