Latest post 08-08-2008 2:37 PM by halid. 6 replies.
Page 1 of 1 (7 items)
  • 08-08-2008 4:40 AM
    Weak IR-signal ?
    I have a Lutron-system with a wall-mounted keypad with a built-in IR-eye in one of my rooms at home. When I use the Beo 5 it is sometimes pretty hard to get the signal to the Lutron-system, I have to be pretty close.
    Can the Beo 5 be set in some sort of "dealer mode" which gives a weaker IR-signal than normal ? I can recall that I have read something about some sort of dealermode somewhere on this site. If so, how do I change this ? Does anyone have any other suggestions or experiences ?
    Best regards
    Hans
  • 08-08-2008 5:10 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Weak IR-signal ?
    You can enter in the Service Menu pressing Standby+Go and then, when cursor is over Options, press 0,0,Go. In the Dealer Options you can change your Beo5 to Normal Mode or Dealer Mode.
    Regards
    Quim
  • 08-08-2008 5:30 AM In reply to
    If you put the Beo5 in dealer mode it reduces the signal.
    Whilst the Lutron IR sensors are less sensitive than the B&O and more directional, nevertheless they do work at a reasonable distance. I suggest you may have a faulty Lutron receiver unit. Have you tried it with the Beo4 to see if you get the same results ?
    Regards Keith....
  • 08-08-2008 9:22 AM In reply to
    Every time I have seen problems with Lutron recieving IR there has been a big BV4 nearby blocking the signal.
    I don't know your room or setup.  But if there is a BV4 in there, I would bet it will work with the TV off and not when it's on
  • 08-08-2008 12:39 PM In reply to
    Certainly, if you have a plasma screen in the same room as the Lutron it will dramatically reduce the IR sensitivity.
    Regards Keith....
  • 08-08-2008 2:34 PM In reply to
    Yes, I have a 7-40 in the same room. I will check if the 5 is set in dealer mode or not. Thanks so far !
    Regards
    Hans
  • 08-08-2008 2:37 PM In reply to
    And it was set in Normal mode, not Dealer. Do you guys have any suggestions how I can improve the signal ? I am not satisfied at all right now...
    Regards
    Hans
