Latest post 05-13-2007 3:04 PM by Roger. 28 replies.
Page 2 of 2 (29 items) < Previous 1 2
  • 05-11-2007 7:44 PM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Southern CA
    • Posts 137
    Re: again
    Well, Its playing DVD, Titel 4 Chapter 11
    and the text is WHITE. The US BeoVision 7 has white text on it, not red.
    -Alex
  • 05-11-2007 9:42 PM In reply to
    Re: again
    Well I like my version better .......
  • 05-12-2007 5:16 AM In reply to
    Re: again
    Alex:
    Well, Its playing DVD, Titel 4 Chapter 11.
    I think you're correct.
  • 05-13-2007 3:04 PM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: again
    "How does it show up if you connect HDR 2 to a BV7 and play something from it? "
    No info in the display - just V MEM, everything else is on the screen - which is nice when you use it from a link room.
    Roger
