Does anyone have a source, or stash, of those pegs? I need two for my S60s and one for my S45s.
~W
are these the ones with the ball & socket type fitting?
Chris.
Yes. About 1.5 inches long and 1/8 inch diameter and the ball is maybe 3/16inch.
Ah - thought so.
My advice would be to look out for some X25's which are rubbish speakers but have the same fixings.
How easy would it be to get these made? Would it be a copyright issue? As you would never be short of people needing them. Almost every pair of speakers I have seen that uses these had at least one that had snapped.
Craig
