Latest post 08-10-2008 6:51 AM by Craig. 4 replies.
Page 1 of 1 (5 items)
  • 08-06-2008 9:36 PM
    • justw
    • Not Ranked
    • Joined on 07-11-2008
    • U.S.
    • Posts 15
    Those little pegs that hold the grill cover on my beovox speakers...
    Does anyone have a source, or stash, of those pegs? I need two for my S60s and one for my S45s.
    ~W
  • 08-08-2008 2:36 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Those little pegs that hold the grill cover on my beovox speakers...
        are these the ones with the ball & socket type fitting?
    Chris.
  • 08-08-2008 5:48 PM In reply to
    • justw
    • Not Ranked
    • U.S.
    • Posts 15
    Yes. About 1.5 inches long and 1/8 inch diameter and the ball is maybe 3/16inch.
    ~W
  • 08-09-2008 6:13 AM In reply to
    • Medogsfat
    • Posts 4,045
    Ah - thought so.
    My advice would be to look out for some X25's which are rubbish speakers but have the same fixings.
    Chris.
  • 08-10-2008 6:51 AM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    How easy would it be to get these made? Would it be a copyright issue? As you would never be short of people needing them. Almost every pair of speakers I have seen that uses these had at least one that had snapped.
    CraigSmile
