        1st March February 2012
	    Latest post 08-04-2008 4:07 PM by  Jandyt. 12 replies.
								        08-04-2008 1:23 PM
									        harrykym
								                - Joined on 08-04-2008
								                - Rossendale
								                - Posts 86
										    does anyone know how to get a STB to work?  and does anyone know how to access the installation setup menu in the avant?  many thanks james
									    BS-3, BS-1, BS-OVERTURE, AVANT-28"RF, AVANT-28" DVD, AVANT 32" RF, 3xBEO-4, LC-1, 4xBEOCOM-6000, BEOCOM-2, A9 KEYRING, DVD1, Beosystem 10, BEOCOM 3, BEOLAB 2500, BEOSOUND CENTURY, BEOLIT 707
									        Jandyt
								                - Joined on 04-01-2007
								                - Clitheroe, Lancashire, UK
								                - Posts 13,004
										    Re: avant STB controller!!
										    Hi James and welcome to Beoworld  We need a bit more to go on, in order to help you. 1 Have you actually got a set-top box controller in your Avant? 2 Do you have the IR cable connected? 3 If so, is it positioned correctly on your STB? 4 Which box are you trying to control, and is it supported in your list? When you say 'installation menu', is this to change the sources on your scarts? If so, then press Menu, then 4 then 5. Andy T.
									        harrykym
								                - Rossendale
								                - Posts 86
										    hi andy thanks for getting back to me so quickly! your right more info would be helpfull 1 yes i have the STB controller  2 yes the IR cable is attached 3 i have stuck the sensor on my sky box 4 i want to control a sky+ box   could it be that the software does not cover my box? it says "sky digital" i have another avant which works the sky+ box, can i just swap the STB's over?  many thanks james
									        harrykym
								                - Rossendale
								                - Posts 86
										    i've just bought the avant today and i want to enter the menu which shows you how many hours the tv has done and service menu ect.
									        Jandyt
								                - Posts 13,004
										    James, Since all Sky+ boxes use the same remote signals, I use the STB called Pace Sky+, even though mine is not a Pace box. If it's not in your list, it might need a SW update. The menu you are looking for is  Menu,4,0,0,Go. Don't mess with anything in there unless you are sure you know what you are doing!
									        harrykym
								                - Rossendale
								                - Posts 86
										    andy! too late i've changed the STB's over and now the menu says "none"!! omg what have i done! all i did was plug the one off my other avant in, simple! maybe not...  please help!!  james
									        harrykym
								                - Rossendale
								                - Posts 86
										    menu 4, 5 then it says AV - none and Decoder - none
									        harrykym
								                - Rossendale
								                - Posts 86
										    how stupid of me - andy your the man!! i've selected pace sky+ for both av and decorder, now i do i make it work my sky box  were do i plug the scart lead into the av or decorder?
									        Jandyt
								                - Posts 13,004
										    I have mine plugged into the decoder scart. The AV scart doesn't need to be set to Pace, I have mine as a DVD.
									        harrykym
								                - Rossendale
								                - Posts 86
										    Andy  All is working!! Thankyou for all your help and putting up with an idiot! Many thanks james
									        Jandyt
								                - Posts 13,004
										    A warm glow has come all over me. You know where we are now. Enjoy your Avant, best telly ever! Andy T.
        Page 1 of 1 (13 items)
