kijf001: are you sure? because of the connection on the backsite? if you are, is it difficult to install a ml module?
Yes I'm sure, Beovision 1 & early Beocenter 1's had the socket for ML but not always the board inside. As for the fitting, it's not too bad but you might want to get a quote from an engineer to do it, it doesn't take long if you know what you're doing.
