Latest post 05-12-2007 2:37 AM by kijf001. 7 replies.
Page 1 of 1 (8 items)
  • 05-11-2007 4:04 AM
    Masterlink connection = option???
    Goodmorning,
    I own a beocenter 1. On the backsite is a masterlink connection. Does this mean that de ML module is available or could it just be the connection without de module?
    cheers
  • 05-11-2007 4:15 AM In reply to
    Re: Masterlink connection = option???
    Give us the type number, it is a 4 digit on the back.
  • 05-11-2007 4:17 AM In reply to
    On a Beocenter 1 it should be standard but an easy way to check is try to put it in 'option 6' if the red light blinks then it has an ML module fitted.
  • 05-11-2007 6:26 AM In reply to
    serial number = 8520
    when v.opt is set to 1 or 2, standby light gives 1 blinck.
  • 05-11-2007 6:39 AM In reply to
    kijf001:
    If it does not blink when you try 'V.OPT 6' then it does not have an ML module fitted.
  • 05-11-2007 7:14 AM In reply to
    are you sure? because of the connection on the backsite? if you are, is it difficult to install a ml module?
  • 05-11-2007 7:47 AM In reply to
    kijf001:
    Yes I'm sure, Beovision 1 & early Beocenter 1's had the socket for ML but not always the board inside.  As for the fitting, it's not too bad but you might want to get a quote from an engineer to do it, it doesn't take long if you know what you're doing.
  • 05-12-2007 2:37 AM In reply to
    Thanks for your help. I will contact the dealer what to do.
    cheers
