Latest post 08-02-2008 12:22 AM by Russ. 11 replies.
Page 1 of 1 (12 items)
  • 07-30-2008 8:54 AM
    does anyone know of an extension cord for active speakers?
    i need help!  i have a beosystem 4500 and just acquired a pair of beolab penta II 's and the din cord is 13 feet long,  i was wondering if anyone knew of a cable or connector that i could find to make the length longer?  any advise would be great!  i love this system and wanna max out on sound quality!  im replacing a pair of rl 2's with the pentas and hope there is a solution?  thanks in advance!
    Filed under: , ,
  • 07-30-2008 9:04 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: does anyone know of an extension cord for active speakers?
    Hi, and welcome to BeoworldSmile
    You can get normal powerlink cables and a little female/female adaptor. This is what I use.
    Andy T.
    Poor me, never win owt!
  • 07-30-2008 11:32 AM In reply to
    thanks so much!  can i get them from bang olufsen?  or ebay?  thanks again!
  • 07-30-2008 12:12 PM In reply to
    • 9 LEE
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Your local dealer should be able to order them for you. They aren't cheap though!
    Lee
    Smile
  • 07-30-2008 3:57 PM In reply to
    thank you thank you!
  • 07-30-2008 5:25 PM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    I have a 20ft mk11 lpowerlink new and unused, if your in UK PM me!
  • 07-30-2008 7:02 PM In reply to
    Another way round this would be to buy a length of powerlink cable from your deal with no DIN plugs terminated on the ends (ie just bare ends). Cut to length, strip the ends and literally splice it into the existing cables and solder the connections.
    It would need to be fully wired in order for the displays to work. This is probably the cheapest way of doing it and arguable the best way for the integrity/reliability of the joint!
    Hope this helps Smile
    Llewelyn
  • 07-31-2008 12:27 AM In reply to
    thanks for the reply! im not in the uk but i would be interested in buying from yoU! i could pay pal the money jus ta thought
  • 07-31-2008 4:29 AM In reply to
    • 355f
    • Posts 655
    hi!
    I think by the time ones adds postage there will not be much of a saving for you even if i let you have it for half price!
  • 07-31-2008 7:35 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    The powerlink barrel adapter is also available from ebay, generally in the USA.  There is a female to female DIN connector available from Maplins or Radioparts (Aus)
    beoaus.
  • 08-02-2008 12:05 AM In reply to
    thanks again! for all the help!
  • 08-02-2008 12:22 AM In reply to
    • Russ
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Just so that you know, PL cables are generally available in 5meter, 10meter and 20meter lengths...by the time you buy the barrel connector and another set of shorter cables, the longer cables may well be cheaper.  Contact your closest B&O shop and explore your options.
     Unless you're dealing with cables already installed inside your walls or something...in which case, never mind.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
