Hi everybody, I have a BV 7-40, a BV 7-32 and a older MX 4002 that I would like to connect by Master Link.
I have connected all devices together and BV 7-40 will be the "master" and I would like the other ones to be links since I have a Dreambox, a X-box and some more devices connected to the BV 7-40 that would be nice to distribute.
Earlier I have connected the BV 7-40 and the MX 4002 with Masterlink and eveything worked perfect. Now, for example, I cant get the DTV-mode to work with the 7-32 and the MX 4002.
I have tried different options ( V-OPT ) but it will not work.
The antenna cable goes from the BV 7-40 to the BV 7-32 and then to the MX 4002.
Can anyone give me some suggestions to a solution to this problem ?
Best regards
Hans
