1st March February 2012
Latest post 08-15-2008 12:35 PM by s0235400. 18 replies.
07-19-2008 5:24 PM
s0235400
- Joined on 04-19-2007
- Posts 28
Serene - DECT communication
Hi everybody, Hope everyone has a good weekend. I'm one of those unfortunate people who bought Serene from Samsung (desktop charger without DECT module). Today I've got new desctop charger (Part No 8080013) from my local B&O shop. As far as I know I should get an additional menu on Serene for registration to my Beoline base (p.n. 1113068) when I connect Serene to that new desctop charger - I haven't got. There is nothing about it in desctop charger manual. Could anyone suggest what might be wrong? Thanks a lot, Sasha
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Serene - DECT communication
I guess you need a software update.
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
When it is on it's dock, press OK Settings Does option number 9 say "Docking Station"? Just out of curiosity, Does it say Bang and Olufsen on the hinge, or just Samsung?
s0235400
- Posts 28
No, there is no option "Docking Station" in Settings when Serene is on the new dock. Serene has both Bang and Olufsen and Samsung on the hinge. According to FAQ about Serene on the main B&O website there is no difference in Serene sold by B&O and Samsung. The difference in only in desktop charger. Regards, Sasha
Jandyt
- Posts 13,004
In which case, I would follow Peter's recommendation and take both your Serene and your new docking station into your dealer for a SW update. Please keep us informed. Andy T.
jvdb107
- Joined on 05-05-2007
- Posts 83
Yesterday I was working at my local B&O shop and our boss told me that if you buy a Serene from Samsung B&O does not condsider it to be a Serene at all. Plus they will charge you (in Belgium) 25 euros
s0235400
- Posts 28
OK guys, thank a lot for an advise. I'll ask my local dealer for Serene software update and keep you informed. Regards, Sasha
s0235400
- Posts 28
I've asked my local B&O dealer about SW update for my Serene (bought from Samsung) and he told me that it is not upgradeable by B&O at all. Is it correct? If yes - Is it due to a technical reasons (connectors, protocols, drivers incompatibility)? Or is it just a administrative barrier to separate responsibility between 2 sell chains? To be honest I don't believe that there are 2 different SW upgrade procedures for Serenes. I'm a programmer for 28 years and I can't find a reason for developers to implement 2 different incompatible SW for the same product. BTW, does anybody know how to check SW version on Serene? Best regards, Sasha
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
To see the software, press *#1234#
To see the firmware, press *#1111# Maybe is on contrary, i am not sure.
s0235400
- Posts 28
Thank you Quim, My Serene returns: *#1234# - E910XXEL3 *#1111# - F-REV1.0C What about your Serene? Regards, Sasha
Jandyt
- Posts 13,004
Mine is *#1234# E910XXFA2 *#1111# F:REV 1.0C Andy T.
Quim43
- Posts 1,030
Mine is *#1234# E910XXFI1 *#1111# F:REV 1.0C Regards
s0235400
- Posts 28
OK, Thanks to Quim and Andy we gain some statistics now. Also the main B&O site provides some information about SW version: http://www.bang-olufsen.com/page.asp?id=378&prodid=562 "You cannot synchronise contacts with Outlook if you have an old software version (software version FC1 or FA1). Only Serene with software version FI1 (or later) can synchronise contacts with Microsoft Outlook. Please contact your Bang & Olufsen retailer to get your Serene updated." According to that info we could see that Andy's Serene can't synchronise contacts when Quim's Serene can. But the most important bit is the fact that firmware version for all 3 Serenes is the same. Thus some questions arise again: - why they told me that SW in Serene from Sumsung can't be updated by B&O? - are there any technical reasons (drivers, etc.) or it is just a policy? - has anyone actually tried and failed or it is just a theoretical knowledge? Any suggestions would be much appreciated. That Serene is my present to my wife and I'm just desperate that I can't do what she asked: to synchronize Serene and Beocom 6000. Best regards, Sasha
Quim43
- Posts 1,030
These are two diferent things: synchronize with Beocom 6000 and synchronize with Outlook. When I bought my Serene, it came with the SW E910XXFC1, and I did synchronize it with my Beocom 6000, but no with my PC. I updated it to the new SW and as I remember, the aplication used to update the SW, deleted everything I had in the Serene (photos, numbers, etc.), and the old SW, of course.
I think your Serene can be updated to the last SW, I don't think it's driver's reason or another technical reason to can't do it. Good luck
s0235400
- Posts 28
Hi Quim, Yes, I undestand that there are 2 different things: synchronize with Beocom and Outlook. Could I ask you to specify: have you run the applicaion to update SW in Serene yourself? Regards, Sasha
Quim43
- Posts 1,030
s0235400:Hi Quim, Could I ask you to specify: have you run the applicaion to update SW in Serene yourself? Regards, Sasha
No, my dealer did, but i was there looking the process. Regards
s0235400
- Posts 28
Hi All, I've got my Serene (bought from Samsung) successfully updated to the latest SW by my local B&O dealer. Now I have the same test results as Quim: *#1234# E910XXFI1 *#1111# F:REV 1.0C But still my Serene doesn't have an option to register to Docking station. Neither my local dealer's personal Serene has. (Although his Serene can register to Docking station at his home.) So now the question is: How to figure out whether the device I've got from B&O dealer is a Docking station or just Desktop charger? There is no serial or part number on it, but in my receipt there is Part No. 8080013. Thanks to everyone for any suggestions. Best regards, Sasha
Quim43
- Posts 1,030
Hi This is my Serene Docking Station: Regards
s0235400
- Posts 28
Hi Quim, Thank you for the photo. Obviously I've got wrong device from my local dealer. Will try to tell it him tomorrow. Regards, Sasha
Page 1 of 1 (19 items)
