Latest post 07-31-2008 10:39 AM by diggs2701. 8 replies.
Page 1 of 1 (9 items)
  • 07-16-2008 10:27 AM
    BeoSystem 1 and Record Player/Turntable
    I tried hooking up my record player, SONY PS-LX350H, to the SAT connection in the back of the BS1 and I get a lot of distortion and the volume has to be turned way up to hear it. I connected it with r/l audio monster cables but there also is a ground that is used on the turntable but there is no ground screw on the BS1. Any recommendations?
     Thank you.
  • 07-16-2008 6:35 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: BeoSystem 1 and Record Player/Turntable
    You almost certainly need a phono pre-amp.  Turntables generally operate at a much lower level than other AV gear.  I found a great deal for a client at PhonoPreamps.com.  Take a look at the second item down on the right side, it did the trick nicely.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 07-16-2008 6:38 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    You forgot the link Russ
    Poor me, never win owt!
  • 07-17-2008 9:42 AM In reply to
    The TCC TC-750LC Phono Preamp:
    Same Great Specs as our TC-750
    PLUS an Output Level Control?
  • 07-17-2008 11:03 AM In reply to
    Russ R,
    Can a turntable be hooked into the Beosystem  1?  I thought it had to go directly to the stereo-audio main such as the BS 9000 or 3200 via pre-amp.
    My BS 1 and BS 9000 are too far apart geographically and the BS 1 location offers more convenience for connecting a tuntable w/ pre-amp.
    Thanks,
    Roger
  • 07-21-2008 3:53 PM In reply to
    I am going to order it, I will post after I recieve and tell you the results. Thanks!
  • 07-30-2008 3:19 PM In reply to
    Got it, works great!!! Thank for all of your help!
  • 07-31-2008 9:26 AM In reply to
    diggs2701,
    Congrats on your success!
    To clarify, you were able to connect your turntable directly to the Beosystem 1 via SAT connection and not through the music system?
    Thanks,
     Roger
  • 07-31-2008 10:39 AM In reply to
    Yes, I connected my turntable to the Phono Preamp (through RCA's and ground) and from there to the SAT connection (Using RCA's) on the BS1. It works great!
    Diggs2701
