I have another question, forgive me as I often do miss the simple things!
My Avant currently has a virgin cable box connected, my understanding is that software in the TV can control the STB via the IR cable connected to the TV and stuck in front of the IR sensor of the STB, this is how the STB receives it's commands from the TV/BEO4.
If you connect Apple TV to the Avant, which has been updated so that it has the correct software, how does it send IR commands to the ATV as my Avant only appears to have one output for this. Or does this operate in a completely different way?
Peter G
