I've got hold of a rather tired Beosystem 5500 with numerous problems and wonder if anyone can shed any light as I'm not familiar with this system
The MCP has loose glass destroying the film that's on the underside. This is just a cosmetic issue I think.
When I first plugged in the system the MCP talked quite happily to the BM but after five minutes decided to throw up a 'no contact' message. Now it will only work if I hold the MCP a few inches away from the front of the BM. MCP has new fresh batteries. I have unpowered overnight and after reconnection it still suffers the same. Any ideas what's happened there & where the fault is likely to lie? It doesn't have the beolink sticker on the back so it won't work with a BL1000 and I don't have access to another MCP 5500 to test.
The CD50 door won't open. Haven't had a chance to investigate properly yet. I can hear a motor working but whether that is the disc or door motor I have no idea. Maybe someone has come across this problem before.
Any input really appreciated.
Thanks,
Steve
If you think nobody cares, try missing a couple of payments.
