mjmedlo: I recently purchased a new mac mini and apple tv for my home. I have iTunes and Beoport connected to the Mini and the apple tv connected or wifi; anyone know why the remote app on iTouch/iPhone will not find my library? It works perfectly at the office, just won't find the library at home?
Will the remote work when I also have the apple tv connected?
MJM
This may help,
Turn on Wifi in settings and connect to your home network in the iTouch or iPhone.
Try it again. ( I hope that I haven't offended you with what you may think are really simple things but i don't know your level of knowledge on the mac) If that hasn't worked and and you were offended by it then get ready to enraged !
Go to system preferences on the mac mini ( the wee cog in a box in the dock or the menu item in the Apple at the top of the screen, furthest to the left on the menu bar)
Then go to security on the top row.
Then click on firewall.
Click on the ball next to: Select access for specific applications and services.
That ball should turn blue.
Then near the bttom of the page there should be a + sign in a box.
A window should appear showing the contents of your system ( this should be familiar because it is the window you get when saving or opening a file)
Go to Applications on the far left hand side ( you may need to scroll down to find it)
Select Itunes ( again you may need to scroll to find it)
Click Add.
Close the system preferences window,
Try it again .
Hopefully that should work but if it doesn't give me an email I'll see if I can find an answer for you ( or send you in the right place if I have offended you too much !)
Alex
