Latest post 07-14-2008 10:22 AM by klassiccarguy. 4 replies.
Page 1 of 1 (5 items)
  • 07-10-2008 4:18 PM
    Beo Sound 9000 connectivity
    I am looking at buying a BeoSound 9000 CD unit, however, it is a European model 220 volts. My question is can I connect my current 120 volt (Penta) speakers up to this system? Also can someone clarify if a model 2571 is a MKII or MKIII. In the product info section it shows MKIII as 2572 and above.
    Ron
  • 07-10-2008 11:23 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: Beo Sound 9000 connectivity
    Type 2571 is a Mk III.  There should be no red power button on the outside of your unit. I see no reason why you can't use your BS 9000 with your Pentas.  Obviously you'll need a step-up voltage converter or internal modification first.
  • 07-11-2008 8:15 AM In reply to
    Thanks Mediabobny,
     I thought they would work but just wanted a second opinion, and thanks for the info on the 2571.
     Ron
  • 07-11-2008 1:33 PM In reply to
    The powerlink is not affected by what voltage the main unit runs on.
    I had a BS2300 European with external 220 to 110 converter  with my US BL3s running a for year.
    Wasnt a problem.
  • 07-14-2008 10:22 AM In reply to
    Thanks ik1002, I purchased the 9000 system so lets hope everything works.
     Ron
