I am looking at buying a BeoSound 9000 CD unit, however, it is a European model 220 volts. My question is can I connect my current 120 volt (Penta) speakers up to this system? Also can someone clarify if a model 2571 is a MKII or MKIII. In the product info section it shows MKIII as 2572 and above.
Ron
Thanks Mediabobny,
I thought they would work but just wanted a second opinion, and thanks for the info on the 2571.
The powerlink is not affected by what voltage the main unit runs on.
I had a BS2300 European with external 220 to 110 converter with my US BL3s running a for year.
Wasnt a problem.
Thanks ik1002, I purchased the 9000 system so lets hope everything works.
