Latest post 07-09-2008 1:16 PM by BeoHelsinki. 5 replies.
Page 1 of 1 (6 items)
  • 07-09-2008 12:56 PM
    Does Beogram 5005 have built-in RIAA pre-amplifier?
    The information I've found on the web is inconclusive, while the best description found is at http://www.beocentral.com/families/bg5005
    "...in both technology and appearance it was basically the same as the Beogram 7000..."
     The Beogram 7000 has built-in RIAA pre-amplifier that I know, but does the Beogram 5005 have it as well?
  • 07-09-2008 1:04 PM In reply to
    Re: Does Beogram 5005 have built-in RIAA pre-amplifier?
    No. Only the 6500 and 7000. The 5005 is identical to the 5500.
  • 07-09-2008 1:05 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    There's an FAQ which may help here.
    However, i can tell you now that the 5005 doesn't have an inbuilt RIAA pre-amp.
    Lee
  • 07-09-2008 1:07 PM In reply to
    The guts are the same as the 7000, except it doesn't have the RIAA.
    You need a 3500,4500,6500 or 7000 if you want an RIAA built in.
    3000,3300,5005,5500,8000,8500 & 9500 & TX2 dont have an RIAA fitted.
    Regards Brett
  • 07-09-2008 1:08 PM In reply to
    3 mins too late!!
    Regards Brett
  • 07-09-2008 1:16 PM In reply to
    Very helpful and fast replies, thank you. Pardon the unnecessary topic, that FAQ is a great resource I'll rely on from now on.
