Latest post 07-06-2008 4:20 PM by Tobias. 3 replies.
Page 1 of 1 (4 items)
  • 07-06-2008 5:46 AM
    • Tobias
    • Not Ranked
    • Joined on 04-17-2007
    • Sweden
    • Posts 32
    Connect a non B&O subwoofer to PowerLink?
    I just bought a Minivee Sub from Velodyne. And I want to connect the sub to my BS3000.
    Is it possible to connect Pin3(brown left ch.) and Pin5(Green right ch.) together? Just want a mono signal to the sub?
    Someone got i wiringdiagram?
    BeoSound3000, Beolab8000, Beovision8-26, Beo5 and BeoCom4
  • 07-06-2008 6:46 AM In reply to
    Re: Connect a non B&O subwoofer to PowerLink?
    Hi, the easiest way to connect a non-B&O sub to your BeoSound is to use one phono to Powerlink cable that B&O sells for BeoLab 3/4/9, and plug it to your system; you'll have a mono signal, that's what I'm using to connect my B&W subwoofer to my BV3-32.
    Reunion Island is greeting you!
  • 07-06-2008 7:07 AM In reply to
    • Bulgarien
    • Top 500 Contributor
    • Denmark, Vest Sjaeland
    • Posts 201
     or try this..
    Here are Peter Pan´s wiring diagram taken from
    http://www.hifi4all.dk/forum/forum_posts.asp?TID=44109&PN=11
     (download and use Google Translate,-its very easy to use...)
      And many others can use this adapter design.
  • 07-06-2008 4:20 PM In reply to
    • Tobias
    • Not Ranked
    • Sweden
    • Posts 32
    Thanks for the help! But is it possible to connect left and right channel together?
    Pin 3 Left together with Pin 5 Right channel?
    Or should i just use one of the channels?
