I just bought a Minivee Sub from Velodyne. And I want to connect the sub to my BS3000.
Is it possible to connect Pin3(brown left ch.) and Pin5(Green right ch.) together? Just want a mono signal to the sub?
Someone got i wiringdiagram?
BeoSound3000, Beolab8000, Beovision8-26, Beo5 and BeoCom4
Reunion Island is greeting you!
or try this..
Here are Peter Pan´s wiring diagram taken from
http://www.hifi4all.dk/forum/forum_posts.asp?TID=44109&PN=11
And many others can use this adapter design.
Thanks for the help! But is it possible to connect left and right channel together?
Pin 3 Left together with Pin 5 Right channel?
Or should i just use one of the channels?
