Latest post 07-02-2008 9:42 AM by Seanie_230. 8 replies.
Page 1 of 1 (9 items)
  • 06-30-2008 3:13 PM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    BV7-40 mkIII doesn't show PS3 start-up or bluray
    After some time, I connected my PS3 again via HDMI. My BV740-MKIII has SW 4.17
    Before everything worked just fine, but now: I don't see the start-up screen anymore, but do hear sound. It also plays stored games, but no bluray's. I can't tell if the problem started after the upgrade to SW 4.17
    Connected to another (Philips) LCD-tv, everything works ok.
    Any solutions?!
  • 07-01-2008 9:10 AM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Re: BV7-40 mkIII doesn't show PS3 start-up or bluray
    anyone got any info on this i have a PS3 and soon a MK3 so want to know it will work perfectly i know HDMI can be hard work detecting at times.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 07-01-2008 11:04 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Try switching to any other source, wait untill you have picture and sound, and then switch back.  I've seen similar problems with some DirecTV Satellite receivers.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 07-01-2008 11:15 AM In reply to
    • JoC
    • Top 500 Contributor
    • Joined on 08-20-2007
    • Northern Ireland
    • Posts 121
    If the PS3 is off, press and hold the power on button for about 10secs, the PS3 will beep, and the video/audio settings will be reset, you can then step through the PS3 init procedure again.
    Sometimes on mine I loose the audio, but if I press DTV on the Beo4, wait, then press VMEM (for my PS3) then then sound comes back, weird...
  • 07-01-2008 1:12 PM In reply to
    • Doc
    • Posts 585
    RussR and JoC,
    Will try tonight and let you know if it worked.
    Thanks.
  • 07-01-2008 3:38 PM In reply to
    • Doc
    • Posts 585
    JoC,
    You were right: it works again! Thanks again.
  • 07-02-2008 8:46 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    I did not think of the reset settings function i have used this b4
    i woudl liek ot ask
    I have just ordered my MK3 and willbe connecting PS3 to my TV via HDMI and wanted to know if you have the HDMI and SPDIF connected or if its all being done with the HDMI
    I know my sky box will use HDMI and TOSLINK / SPDIF as sky hdmi does not contain dobly but the PS3 does so will it work or do i need to buy another TOSHLINK and convertor to SPDIF
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 07-02-2008 9:38 AM In reply to
    • JoC
    • Northern Ireland
    • Posts 121
    seanklemis:
    i woudl liek ot ask
    Just use the HDMI cable for the PS3.
    As for the SkyHD I would of thought again you would only need the HDMI cable and not the TosLink, because the TosLink would only be used if you are connecting the video via the component cables, or am I missing something?
  • 07-02-2008 9:42 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    yeah i have been told that SKY does not transmit DD over the HDMI so it needs to stay seperate silly really ?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
