Hello All
I work in IT and i knwo that a beomedia is just a computer.
has anyone cleaned there's out?
has anyone cloned the hard disk in case or fatel hard disk failure.
if you loose all the operating system when can it be recovered from etc?
Beovision 7 MKIV (Blu Ray)Beolab 9Beolab 6000Beo 4Beocenter 9300Apple TVSKY HDOptoma HD65 ProjectorLintronic TT455-RT-238Beovision 3 MKII
When you are in the Beomadia menu, press the Red button and then 9.
You will see the configuration menu. Press 0,0,GO, and you will see the last function of this menu is Recovery. Use it to leave your Beomedia with factory settings.
Quim
hi there
i know you can go to recovery builder but if the hard disk fails you wont even be able to get to the menu as no operating system woudl load?
how can you extend it's disk capacity ?you can easily connect an usb disk, but how can you tell the soft to index the photo and music files ?
nico
