Latest post 06-27-2008 11:38 AM by nico vercammen. 3 replies.
Page 1 of 1 (4 items)
  • 06-27-2008 9:00 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Beomedia Service
    Hello All
    I work in IT and i knwo that a beomedia is just a computer.
    has anyone cleaned there's out?
    has anyone cloned the hard disk in case or fatel hard disk failure.
    if you loose all the operating system when can it be recovered from etc?
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 06-27-2008 9:57 AM In reply to
    • Quim43
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Beomedia Service
    When you are in the Beomadia menu, press the Red button and then 9.
    You will see the configuration menu. Press 0,0,GO, and you will see the last function of this menu is Recovery. Use it to leave your Beomedia with factory settings.
    Quim
  • 06-27-2008 10:17 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    hi there
    i know you can go to recovery builder but if the hard disk fails you wont even be able to get to the menu as no operating system woudl load?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-27-2008 11:38 AM In reply to
    how can you extend it's disk capacity ?
    you can easily connect an usb disk, but how can you tell the soft to index the photo  and music files ?
    nico
