This is my first post and also my first B&O system. I have a BeoVision 4-42, BeoSystem 1, BeoLab 4000's, BeoLab 8000's (on there way, not hooked up yet), BeoSound 3200 with a beo4 remote. I was wondering if there was anyway to hook up component cables from a HD Digital Cable Box (Comcast Motorola DCT 3416) (Y,Pb,Pr) to the BeoSystem 1 (Y,Pb,Pr,H,V)?
I have tried hooking up the wires with H and V left disconnected and the audio going to the audio of the STB connection panel but I get no video. Also, I spoke with a B&O installer and they recommended I upgrade my software and chipset on my BeoSystem 1 and was wondering if it was worth it?
My last question has to deal with a setup menu that pops up on the BeoVision 4-42 everytime I power it on or change a source (I think the menu is from the beosystem 1 but my beo4 can't control it). The menu (blue) will pop up for about 2 minutes then go away and I was wondering if there is anyway I can have it not show up? Thank you in advance,
 Diggs2701
