beoaus:
Here we go Beoaus!
Vicente has a BV7-40 mk1 upgraded with the HDReady kit to a mk2, he was trying the gefen hdmi switcher which works in 2 different ways, in a "B&O compatibility" mode and in a "generic mode",
finally the only mode that works with the BV7 is the "B&O mode" that don't use the spdif digital audio out of the gefen, and all the external HD devices must plug their digital audio outputs directly to BV bypassing the hdmi switcher.
In this mode the switcher works perfectly well and can be controlled by beo4 and beo5, but the BV7 lose one scart input for each hdmi source you want connect.
Vicente in fact was searching to use all the SD scarts inputs and add 4 hdmi sources via the BV7 DVI plug, with a full beo4-beo5 control, but this is not possible, so he has decided to sell his BV7 mk1 "upgraded" and go for a brand new BV7 mk3. (does any buyer interested here??
Hope this helps.
Regards.
