Hi Keith...
Thanks for the info....
Not sure how old the 3500s are....
"I am assuming the master cable routing is daisychained 3200 to TV to 3500 to 3500 or is it in a star configuration ?"
There is a masterlink cable coming from the 3200....There is also a masterlink cable coming from the TV...Both
these cable dissapear behind a unit I really dont want to have to move...then a cable goes out to the 3500 that
I beleive are daisy chained together.....all installed by B&O
A contractor for a TV firm cut through the masterlink cable that goes outside and up into the
loft space on its way to the 3500s....This was repaired by B&O....
"When you use the remote to turn on either of the 3500's does the display change from standby ?"
Yes....They do come out of standby....
"With the radio or CD on at the 3200, press the mute button on each of the 3500's does the unit come on ?"
Have tried this but they simply wont play the chosen source playing on the 3200......
The thing thats strange is that when powered of sometimes and only sometimes the 3500 both work
for a limited period of time....IE...once then when turned of thats it again....
Cheers for the help....
Gav....
