Hi Martin,
as usual I wasn't precise enough You are absolutely right 74.8 is all it's showing the LED appears to be fine and showing the time.
 I would be gratefull for a chip  can I email you tomorow I think I may have a list of things I need.
Thanks as always for your help,
cheers,
Kevin
