Hi all!
I have som problems to get my beoport to work and have som questions:
Does all BS3000 has the possibility to play N-music with beoport? I have on with the small CD-cover (SW 1.2).
If its located in the same room as my BV7 (opt 2), BS3000 (opt 0) and a Mac with BM-link, does it matter in what option the beoport set to if its connected with ML only?
They are connected by a ML-distibutor box. BV7 connected to Video, BS3000 to Audio and the beoport to one of the other.
I can see in the BM-link that that the mac communicates with the beoport since I was able to do a firmware upgrade.
The problem is that iTunes doesn't start to play,BV7 or BS3000 doesn't show N.Music.
Can anyone se what I've done wrong?
All help is allways appreciated!
/Ola
