Latest post 06-13-2008 1:53 PM by Craig. 6 replies.
Page 1 of 1 (7 items)
  • 06-12-2008 1:46 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beoport - Input voltage question
    Is it possible to change the operating voltage of a Beoport? Mine is 240 volt but can it be changed to operate on 100 volts? Or were there two different versions produced?
    CraigSmile
  • 06-12-2008 3:07 PM In reply to
    Re: Beoport - Input voltage question
    Craig,
    There are about seven different versions of Beoport
    Type 1670 is for EU except UK & Ireland
    Type 1672 is for UK
    Type 1673 is a 110 volt version for North America
    Regards Keith....
  • 06-12-2008 3:35 PM In reply to
    • Craig
    • Posts 4,855
    Thanks Keith.
    CraigSmile
  • 06-12-2008 3:50 PM In reply to
    • mor
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Cologne
    • Posts 104
    I am using the UK version in Germany with no problem, by the way (but that doesnt say you should try with an EU version in the US :-)
  • 06-12-2008 3:57 PM In reply to
    • Craig
    • Posts 4,855
    mor:
    Different voltages though, so I cannot see that it would work.
    Craig[:)}
  • 06-13-2008 2:00 AM In reply to
    Actually Craig, a UK version will work in Europe because the only difference is the power plug, they are the same voltage.
    However you cannot use a UK or EU version in North America unless you connect it via a stepup transformer.
    Regards Keith....
  • 06-13-2008 1:53 PM In reply to
    • Craig
    • Posts 4,855
    Keith Saunders:
    Yes, I meant a U.K. version will not work on 110 volts. As you say the only difference between the EU and UK versions will be the mains lead.
    CraigSmile
