Latest post 06-13-2008 4:09 PM by Jandyt. 4 replies.
Page 1 of 1 (5 items)
  • 06-12-2008 11:29 AM
    • Fil
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 90
    Tuning BM 7000 with Beo 4
    Hi everyone.
     I have a Bs7000 linked to my Avant.
    I wanted to tune a radio station in today but couldn't work out how to do it with a mk 3 Beo 4.
    I have a BL 7000 but the battries were flat and after charging the dreaded "no contact" appears.
     I really cant be bothered removing all the components and adding them again to get it working ( not really sure how to anyway).
    So, can anyone tell me how to tune the radio with the Beo 4?
    Thanks in anticipation for any help.
    Fil
  • 06-12-2008 3:56 PM In reply to
    • mor
    • Joined on 04-18-2007
    • Cologne
    • Posts 104
    Re: Tuning BM 7000 with Beo 4
    This will not be the answer you eventually look for - but how about operation that while the BL7000 stays on the charger?
  • 06-12-2008 6:45 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Fil.
    You have to 'trick' the Beo4 into thinking it's tuning the Avant!
    Look at THIS THREAD to find out how.
    Andy T.
    Poor me, never win owt!
  • 06-13-2008 6:30 AM In reply to
    • Fil
    • Posts 90
    What a Kerfuffle!
    BUT,it worked!!.........thanks Andy , you're a genius!
    While you're there............any threads to the removing/replacing of the components on the BL7000 as it's saying no contact at the mo , although i understand that it's only one way at the mo as it's linked to my Avant.
    Thanks again
    Fil
  • 06-13-2008 4:09 PM In reply to
    • Jandyt
    • Posts 13,004
    Fil, it should still work Two-way with your 7000 system.
    To remove the components, press 'Mask' until you see panel
    Press 'panel' then 'set up' then 'system' then 'components' then 'audio.
    You should then see the list of components on the top row. (Radio, A Tape CD etc)
    Touch each one on the bottom row until they disappear from the top row then touch 'Store' (Don't forget to press other in case thwere are more on the next page.)
    Add them again by putting them on the top row again and press 'Store'
    Make sure you are in range of the Beomaster when you press store.
    Do you have Passives connected to your Beomaster 7000 and Beolabs connected to your Avant, as I do?
    Andy T.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
