Hi all,
Well I decided that I needed an upgrade and went for one on e-bay from La Belle France! Probably should have waited for one with original packaging, as this one received some transit damage! It does however work, and now that I've changed the language I can at least see what it's telling me it's up to! I love the look and the very ergonomic twirly wheels at the bottom, it also seems to play CD's fine - not tried radio or SD card but will soon. Even my older Beo 4 with A-tape seems to work the SD card function too so I'm happy with that as well!
Now to the sadness!
The lovely sliding glass door is somewhat askew, and makes a nasty clicking noise when it reaches it's uppermost opening position. On inspection with the door off, the retaining brackets located within the slots are not level, and I'd like to know if it's easy or even slightly challenging to rectify this? If I need to seek B&O assistance then I suspect any savings on new price might be lost! ( This was not the best deal on the planet!)
The other damage sustained is to the dark grey plastic insert in the aluminium base which locates the cables. This has in fact broken in half and may be able to be glued (shudder the thought of using some sort of super glue type nasty on such a wonderful piece of engineering but........) Can I buy one of these as a spare part? If so are they hideously expensive?
I'm a happy bunny really, as it's here and it works! I'd just be a lot happier if I could resolve these little glitches, so any help will be gratefully received.
Cheers
Peter
