1st March February 2012
Latest post 06-13-2008 7:40 PM by Russ. 25 replies.
06-05-2008 12:32 PM
linder
- Joined on 04-16-2007
- Posts 653
In several posts about the forthcoming Beosound 5, there has been mention of a software upgrade to Beomedia 1. Is this still true or at least a possibility? I hope that if there are changes, they will include the ability to add an internet radio station manually instead of the limited list that B&O provides. I have other suggestions but didn't want to rant too much. We have mostly talked about the design of the future BS5 or BC5 which I agree will probably be exceptional but if it isn't much more that a standard Windows media player, it will be a disappointment. The Beomedia 1 is the first Bang and Olufsen that I have ever purchased that was obsolete from the beginning and could not be upgraded. The dealer experience wasn't much fun either.
Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002 BL11
Alex
- Bath & Cardiff, UK
- Posts 2,990
Re: Beomedia 1 Future????
B&O won't drop the support for all BeoMedia 1 users. I'd wait and see what happens
Weekly top artists:
linder
- Posts 653
They do listen at B&O. I was annoyed that an internet radio station that I especially like was removed from the Beomedia 1 database. I received an email from Beocare who said they have added the station in question. Maybe there is a Beosound 5 in my future.
Roger
- Joined on 03-28-2007
- Norway
- Posts 870
The BeoSound 5 will work with the BeoMedia 1. The new software will be released for the BeoMedia 1 this fall when the BeoMaster 5 is launched (at the same time as the BeoSound 5, of course). I've heard a rumour that more info could be made available on BeoWorld in the near future... Roger
Coolskin
- Holland
- Posts 505
Roger: The BeoSound 5 will work with the BeoMedia 1. The new software will be released for the BeoMedia 1 this fall when the BeoMaster 5 is launched (at the same time as the BeoSound 5, of course). I've heard a rumour that more info could be made available on BeoWorld in the near future... Roger
Dear Roger, You speak in riddles! Beomaster 5, BeoSound 5... Never mind. Found more info on the beoworld Dutch forum. http://forum.beoworld.org/forums/1/118502/ShowThread.aspx
Roger
- Norway
- Posts 870
The information we (BeoWorld) have states that the BeoSound 5 will be the panel and the BeoMaster 5 will be the "socket unit" if you think along the lines of the BeoCenter 2. As ML will be used between them, we are confident that the BeoMaster 5 could be seen as a BeoMedia "2" - making sure that current owners of the BeoMedia 1 can take advantage of the BeoSound 5 (the BeoMaster 5 will have better tech specs, of course, compared to the BM1). When the BeoMaster 5 is launched with the new fancy sw, this sw will also be uploaded automatically to current BeoMedia 1 owners. The BeoMaster 5 will be an option for the BeoVision 9, as BeoMedia 1 was up until recently when it was discontinued. We do not know of any limitations by using the BeoMedia 1 and not the BeoMaster 5 yet. Roger
linder
- Posts 653
Roger: The information we (BeoWorld) have states that the BeoSound 5 will be the panel and the BeoMaster 5 will be the "socket unit" if you think along the lines of the BeoCenter 2. As ML will be used between them, we are confident that the BeoMaster 5 could be seen as a BeoMedia "2" - making sure that current owners of the BeoMedia 1 can take advantage of the BeoSound 5 (the BeoMaster 5 will have better tech specs, of course, compared to the BM1). When the BeoMaster 5 is launched with the new fancy sw, this sw will also be uploaded automatically to current BeoMedia 1 owners. The BeoMaster 5 will be an option for the BeoVision 9, as BeoMedia 1 was up until recently when it was discontinued. We do not know of any limitations by using the BeoMedia 1 and not the BeoMaster 5 yet. Roger
Thanks for the very good summary of the Beosound 5 and Beomaster 5. Because ML is being used, I assume the BS5 can be in a bedroom for example and the Beomedia 1 or Beomaster 5 can be located in another room or cabinet. Unless the Google translator is really bad, there was a discussion in the Dutch forum of iTunes being available. Is that possible?
PhilLondon
- London
- Posts 2,545
I am wondering if BM5 will look like the DVD2/HDR2?
beojeff
- Joined on 11-29-2007
- Posts 543
I'm hoping the same thing for the Beomaster 5. I was also hoping the the Beosound 5 unit would be shaped in an oval like the BC2, but I think the Beosound will be rectangular.
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
The BeoMaster 5 & the BeoSound 5 are not connected with ML.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
PhilLondon
- London
- Posts 2,545
TripEnglish: The BeoMaster 5 & the BeoSound 5 are not connected with ML.
Ethernet?
Santiago
- Switzerland
- Posts 3,286
wtlc2zpx: TripEnglish: The BeoMaster 5 & the BeoSound 5 are not connected with ML.
Ethernet?
Wireless?
TripEnglish
- America
- Posts 1,595
Neither. It's essentially wired like a BeoVision 4.
Roger
- Norway
- Posts 870
So only ML on the BeoMaster 5, and the BeoSound 5 is connected as a display via RS232? This will limit BV9-owners when it comes to placing the BS5 (if they build the BeoMaster 5 into the tv's cabinet). As album art is provided by the BeoMaster 5 to the BeoSound 5, I guess ML alone wouldn't be enough - so RS232/VGA/or something similar makes sense. Roger
TripEnglish
- America
- Posts 1,595
While it may not be too early to wonder about the BeoSound 5 / BeoMaster 5, it is a bit early to start worrying about it. Connectivity will be no more an issue with the BeoSound 5 than with any other previous product. Once there is an official nod from Bang & Olufsen that the product even exists, I'm sure that we'll find it even harder to keep mum.
linder
- Posts 653
TripEnglish: While it may not be too early to wonder about the BeoSound 5 / BeoMaster 5, it is a bit early to start worrying about it. Connectivity will be no more an issue with the BeoSound 5 than with any other previous product. Once there is an official nod from Bang & Olufsen that the product even exists, I'm sure that we'll find it even harder to keep mum.
If it didn't exist, why did B&O give us a clue around last Christmas. You don't want to tease dedicated customers. Flappo, If BS5 is compatible with Beomedia 1, it is MS Windows and probably an imbedded version. In the meantime, my AppleTV works just fine.
TripEnglish
- America
- Posts 1,595
It obviously exists. See link: http://en.wikipedia.org/wiki/Humour#Understanding_humour I meant more along the lines of a press release or some other act of introduction. It will, by the way, run on Energon® Cubes and feature a cooled compartment for spreadable meats.
linder
- Posts 653
TripEnglish: It obviously exists. See link: http://en.wikipedia.org/wiki/Humour#Understanding_humour I meant more along the lines of a press release or some other act of introduction. It will, by the way, run on Energon® Cubes and feature a cooled compartment for spreadable meats.
These are very serious things that we talk about here. However I thought the cooled compartment was optional.
TripEnglish
- America
- Posts 1,595
It was initially discussed as optional, but the new CEO has confirmed our long-term commitment to spreadable meats. Expect the doors of the BeoCenter 2 to open to a tin of duck pate by fiscal year 09/10. (I've already said too much)
Flappo The Grate
- Posts 703
i'll stick with bno as the gratest transceiver producers , speakers and tv , the middle bits i'll leave to apple as they REALLY know their stuff ta very much :)
nlb
- Posts 60
OK ... so the BeoMaster5 is a MS PC while the BeoSound5 is a mini LCD screen! Simple.
I'll stick with my Apple iTouch thanks very much.
nlb.
TripEnglish
- America
- Posts 1,595
I think Trip's basket of Kittens must be pulling his leg. A beer cooler, now that I could understand. I do think it will be interesting to see how B&O address the different situations presented by an audio-only BS-5 set up and one involving a BV-7 or 9. Russ
