Latest post 06-02-2008 2:38 PM by camshaft. 7 replies.
Page 1 of 1 (8 items)
  • 06-02-2008 4:26 AM
    My dad's 1987-88 Beosystem in storage ..
    My dad was clearing out his storage and asked me whether I wanted his Beosystem complete from about 1987 or so,
    which he had B&O Hong Kong come and installed in his flat. When he sold the flat later in 1992, he had the system
    moved into storage. The catch has been that sometime between going into storage and now, no one can find the
    wire harness that tie the whole system together. Without it .. the system is useless of course. Well, I told him I'll
    take it and don't throw it away. But I probbably had to have good luck to locate the entire wiring speghetti that goes
    behind the Beosystem from that vintage. Can someone point me in the right direction to try and find the part(s) I need ??
    Thanks in advance!
  • 06-02-2008 5:27 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: My dad's 1987-88 Beosystem in storage ..
    Take some pictures and/or post type nr. (see stickers on the back), so we know what system you are talking about.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 06-02-2008 5:36 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Welcome to Beoworld DudemanSmile
    We do need a bit more information to be able to help you. It shouldn't be too difficult though.
    Andy T.
    Poor me, never win owt!
  • 06-02-2008 6:23 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    It's almost certainly worth keeping though, some of these old systems are still worth a lot of money - some of them will sell for over £1500.
    Getting hold of the cables is relatively easy...
     Weekly top artists:
  • 06-02-2008 10:53 AM In reply to
    Thanks for the welcome and the replies. I'm getting good vibes that we may be able to restore the system. I absolutelye fell in love with it when I stay in the extra bedroom while on school break. It's one of those that has the tower speakers and that you can turn on the system from any room. No worries. I saved it from the garbahe pile or from it going to someone who has no idea what it is .. Once I get it (it has to be shipped over to where I am), I'll be posting pictures right here. The main components do look like those 5000, 5500, or 6500 being silver squarish little stackable modules. Stay tuned & thanks in advance! ;)
  • 06-02-2008 11:01 AM In reply to
    well, the listed components *should* have all the leads integrated? i.e. they should all plug into the master w/o anything extra.
    you likely need the leads to the speakers (whatever they are -sound like maybe pentas) -depending on wether they are active or passive will determine which leads you require.
    you likely will also need an am and/or fm aerial.
    i think you may be much closer to re-assembling this than you think.
    let us know how it goes, and welcome to beoworld!
    ++++edit++++
    re-reading your post, it sounds as though this may also have some mcl82 or mcl components for link rooms. that, of course is a different matter. i would suggest getting the main system up and running first, and then we can help you out w/ what cabling you may require for the link room(s)...
    ++++edit++++
    • B&o bottle opener
  • 06-02-2008 11:02 AM In reply to
    • Alex
    • Posts 2,990
    If it's a 5500 system or similar (5000, 5500, 6500 and 7000 are all part of the same group) then it's still one of the best systems B&O have made...
     Weekly top artists:
  • 06-02-2008 2:38 PM In reply to
    • camshaft
    • Top 150 Contributor
    • Pennsylvania, USA
    • Posts 575
    Yes, it sounds like a 5500 system with Pentas.  Definitely one of the better B&O systems.  As Jeff above me mentioned, it sounds like the mess of wires you mentioned was only for the multi-room linkage, and won't be necessary for setting the system up and listening to it in one room.  The components of the system should have permanently attached cords, which will plug into the back of the beomaster (receiver).
    Austin
    -Austin (resident audiophile skeptic)
