well, the listed components *should* have all the leads integrated? i.e. they should all plug into the master w/o anything extra.
you likely need the leads to the speakers (whatever they are -sound like maybe pentas) -depending on wether they are active or passive will determine which leads you require.
you likely will also need an am and/or fm aerial.
i think you may be much closer to re-assembling this than you think.
let us know how it goes, and welcome to beoworld!
++++edit++++
re-reading your post, it sounds as though this may also have some mcl82 or mcl components for link rooms. that, of course is a different matter. i would suggest getting the main system up and running first, and then we can help you out w/ what cabling you may require for the link room(s)...
++++edit++++
