Latest post 05-25-2008 5:37 PM by beoaus. 3 replies.
Page 1 of 1 (4 items)
  • 05-25-2008 11:28 AM
    Can you use the RECORD button to record on sky+?
    I have and Avant DVD with a set-top box controller. It doesn't have a video recorder, HDR or a DVD2 connected, so the RECORD button isn't used for anything.
    Can you customise a Beo4 so I don't have to press MENU-8 to control recording on Sky?
    Thanks.
  • 05-25-2008 11:49 AM In reply to
    Re: Can you use the RECORD button to record on sky+?
    Unfortunately you cannot customise the "Record" button on a Beo4, perhaps you may wish to invest in a Beo5.
    Regards Keith....
  • 05-25-2008 12:37 PM In reply to
    To record on Sky+, you just press Go Red on the Beo4.
  • 05-25-2008 5:37 PM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Go 8 also works
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
