Latest post 05-25-2008 7:22 AM by futurist. 6 replies.
Page 1 of 1 (7 items)
  • 05-24-2008 10:08 PM
    BeoSound 9000 Wall Mount Query
    I suspect I know the answer to this already, but I'll ask anyway.
    Someone is selling the small bracket part (which attaches to the wall) of the system used to horizontally mount a 9000. They are not selling the larger backing plate which attaches to the 9000 however. I have my 9000 on a floor stand. Is it possible to use the backing plate from this with the small bracket I referred to? Or are the backing plates different for each of the (vertical and horizontal) mounting systems?
    Thank you
    Stuart
  • 05-24-2008 10:18 PM In reply to
    Re: BeoSound 9000 Wall Mount Query
    I am pretty sure they are different. The wall part has too "claws" that need to be inserted into the backplate and I doubt the stand version has those. I have the vertical wall mount and there are no inserts for the claws from the horizontal mount.
    You can get the individual pieces as spare parts though.
  • 05-24-2008 10:24 PM In reply to
    agreed, i believe all of the mounts are unique relative to their axis orientation...
    • B&o bottle opener
  • 05-25-2008 5:48 AM In reply to
    Hello,
    2054 - horizontal wall bracket, 2063 - vertical wall bracket. These brackets are different, both big plate mounted on the rear panel of hifi and smaller flat hook - mounted onto the wall.
  • 05-25-2008 5:52 AM In reply to
    Floor stand has different back-plate
  • 05-25-2008 6:58 AM In reply to
    All the brackets come with thier own mounting plates for the BS9000 and wall so if buying used, make sure there are two parts.
  • 05-25-2008 7:22 AM In reply to
    Thank you everyone for your replies. As I a suspected, one part without the other is useless - which is probably why it's being sold.
