Latest post 11-30-2010 11:57 AM by macjonny1. 30 replies.
Page 2 of 2 (31 items) < Previous 1 2
  • 09-15-2010 12:49 PM In reply to
    Re: Beolink 7000 keeps switching on and off
    burantek:
    Well, I guess I'll be relegated to using it in the charger as well!
    I never put my BL7000 back together after these threads -hoping that someone might have a solution.
    In the meantime... any confirmation from users that the BL7000 remains stable when used solely from the charging stand?
    • B&o bottle opener
  • 09-16-2010 1:00 PM In reply to
    My "bad" BL7000 still works all fine in charger but to be honest I dont use it that much since i have a "good" BL7000 that is my joy :). One downside with the "bad" BL7000 that im abit worried that I never "execise" the battery in the same fashion I do with my "good", since the "bad" mostly sits in the charger.....
    Cheers
    Jesper
  • 10-17-2010 8:58 PM In reply to
    • MartinM
    • Not Ranked
    • Joined on 08-07-2008
    • New Zealand
    • Posts 49
    @ Leslie, I did a recap and battery replacement and that resolved the issue for me. Can be viewed in this thread here
    http://forum.beoworld.org/forums/p/35867/297765.aspx#297765
    I would do basic check:
     Battery is good and producing 6 volts?
     Pin 10 on the ribbon cable is at 5Volts when BL is on and 0 volts when off. If it is, then issue is with the analogue board. If it’s not, then issue is the digital board.
     Check with a meter that there is continuity in the ribbon cable ie. No break.
     Reseat the ribbon cable.
    Next:
    If you have two BL’s try compare voltage readings on same parts of the board between the two.
  • 10-18-2010 3:55 PM In reply to
    Good job MartinM! I have 5x BL7000 now and one of them is still having this issue.
    Hopefully the options you mentioned will solve it! Will keep you updated, for sureYes -  thumbs up
    Leslie
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 10-23-2010 8:18 AM In reply to
    Check the voltage of the back-up battery on the microprocessorboard.
  • 11-30-2010 11:57 AM In reply to
    If you are looking for an LCS I have one.  Currently on ebay.  Pricey but I would give a discount to a fellow Beoworld member.
