Latest post 05-25-2008 5:28 AM by stefan. 5 replies.
Page 1 of 1 (6 items)
  • 05-24-2008 10:39 AM
    Beosystem 7000 in a link room?
    Hi!
    Is it possible to have a Beosystem 7000 in a link room working as a slave?
    My other setup is a BV7+BS4 in the main room and a BC6 in one of my linkrooms were I want to put the BS7000.
    My goal is to use the speakers in the BC6 for the BS7000.
    Should the BS7000 be set to Option-0? (I don't think it's possible to set the BS7000 to option-5 or 6)
    (I have a converter model 1611 for connecting the BS7000 to ML)
    So, is this possibe?
    Regards Ola
  • 05-24-2008 1:18 PM In reply to
    • mor
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Cologne
    • Posts 104
    Re: Beosystem 7000 in a link room?
    To my knowledge the non-Masterlink stereos can not be set to slave mode - But maybe somebody proofs me wrong on this forum.
  • 05-24-2008 3:41 PM In reply to
    Exactly what I thought.
    But what happens if i connect it as option-0?
    Or is there any other solution?
  • 05-24-2008 4:01 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    BS 7000 slave mode (option 5, 6) is not possible. But what about setting the BC 6 to option 4, BS 7000 to option 1 or 2.
    You can control your main system via Link commands and the BS 7000 as an audiomaster.
    I have a BS 7000 in a linkroom with an MCL 2A in option 4 connected via an ML-MCL converter to my main system BV7 - BS 9000.
    So I control my main system in the linkroom via link commands.The MCL 2A is connected to the AUX input of the BS 7000 via a Hi-Lo level converter. Works great.
    Hope this helps
    Stefan
  • 05-24-2008 6:28 PM In reply to
    Thanks for your replay!
    What option is your BS 9000 set to?
    So mine should be:
    BV7 in option 2, BS4 in option 0
    BC6 in option 4, BS 7000 in option 2 (or 1?)
    Best regards
    Ola
  • 05-25-2008 5:28 AM In reply to
    • stefan
    • Posts 1,733
    Hi Ola,
    my option settings are:
    BV7 option 2, BS 9000 option 0 (mainroom standard configuration)
    linkroom: MCL2A option 4, BS 7000 option 1, MX 4000 option 1.
    My BS 7000 is in option 1, because as you can see I have also an MX 4000 as a link TV, but not connected to the audiosystem.
    In addition to that I have an MCL 2A in the mainroom in option 4, connected to the BS 7000 so I can control and listen to my BS 7000 (record player) in the mainroom via BS 9000.
    For you BS 7000 in option 1 or 2 should both be fine, because the system won`t react to video LINK-commands.
    Good luck
    Stefan
