I own a Bang and Olufsen Beosound 2300.
I want to hook my computer up to the system so I can use it to play my iTunes.
That is the best (i.e. cost effective) way to accomplish this? The computer will be in a separate room from the Beosound. Can I hook them up via some sort of cable that will connect directly into my computer. Or will I need to purchase a receiver. I would like to avoid the receiver optoin as they seem to be $500+ for good quality.
Thanks!
