Latest post 05-21-2008 6:03 PM by MoglesMac. 6 replies.
Page 1 of 1 (7 items)
  • 05-21-2008 5:13 AM
    remote for beomaster 5000
    a quick question :
    can this TV remote use with my beomaster 5000 ?
  • 05-21-2008 5:15 AM In reply to
    Re: remote for beomaster 5000
    Afraid not. Only MCP5000 is suitable.
    Regards Graham
  • 05-21-2008 5:29 AM In reply to
    joeyboygolf:
    Not quite true. A Terminal 5000 will work and is less bulky than the MCP.
  • 05-21-2008 5:45 AM In reply to
    thank you , guys .
  • 05-21-2008 6:16 AM In reply to
    j0hnbarker:
    joeyboygolf:
    Quite correct, I always forget about that!
    Regards Graham
  • 05-21-2008 6:25 AM In reply to
    joeyboygolf:
    j0hnbarker:
    joeyboygolf:
    Quite hard to find these. I waited about 6-8 mths for a good one to come up on eBay. Hardly ever use it though!
  • 05-21-2008 6:03 PM In reply to
    I had a "IR-converter" that looked much like a "X-tra Speaker Kit" wich i recall was able to be used with diffrent of pre-beolink1000 models, including Beomaster 5000 (i might be wrong tho). I traded my for a real "X-tra Speaker Kit" wich was what i wanted when I bought it.
    Traded it with Peter here on site :D since he was very intrested in the manual.
    MoglesMac
    Sweden
