tournedos:Anybody know how this stuff works on MCP6500? The Beosystem 6500 manuals on site only talk about Beolink 7000
("Control" is another mystery button...)
My Beosystem 6500 manual mentions the MCP 6500.
Unfortunately, it is in Dutch,
but i will translate it :
Choose source (except RADIO), and while the system is playing, press Play Next,
choose the `next` source.
Play Next can be used 10 times in a row.
When the displays shows `No Input`, the sequence has reached maximum.
Switching to standby will delete the Play Next-list, however pressing Stop will pause the Play Next-list,
pressing Play to continue the Play Next-list.
The sources that can be added to the Play Next-list are : CD, PHONO, TAPE and TAPE 2.
One can choose a radio-preset-channel as the last source of the sequence,
but the system will not switch of after the sequence.
To check the sequence, press Play Next, the press STATUS repeatedly,
the chosen sources will be displayed one after another.
