Latest post 05-09-2007 2:54 AM by marcus_m. 3 replies.
Page 1 of 1 (4 items)
  • 05-07-2007 12:06 PM
    • benkap
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Oslo, Norway
    • Posts 162
    DVD5500 - can you make one?
    I have aqquired a CD5500 with some small fault that are probably easily repaired.
    However, I would like [someone more skilled than myself] to turn it into a DVD5500.
    I also have a Kiss DP-1500 with a built-in IR converter so that it responds to the B&O IR codes. If you have the skills to transfer the insides of this unit to the CD5500 chassis please contact me.
    Thanks,
    Ben
  • 05-08-2007 2:46 AM In reply to
    Re: DVD5500 - can you make one?
    Hi Ben,
    Our German beoworlder might be able to help you? Have a go and ask mister Ulf Kiener to help you. Check his website:
    http://www.ulf-kiener.de/tick_e.html
    He actually has a DVD player for sale now, design Beomaster 7000. (He also placed a DVD player into the Beogram CD50)
    Can you help yourself with the German Language?
    Regards Robert
  • 05-08-2007 3:14 PM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    Hi Robert, I have already sent Ulf Kiener an email. It is in English, though. If German is required I can manage. Do you know if Ulf is a current Beoworld user? Thanks, Ben
  • 05-09-2007 2:54 AM In reply to
    Hi Ben,
    yes, he is. His nick is "Ulf". Have a look in the german forum, he's quite active there.
    Marcus
