I have aqquired a CD5500 with some small fault that are probably easily repaired.
However, I would like [someone more skilled than myself] to turn it into a DVD5500.
I also have a Kiss DP-1500 with a built-in IR converter so that it responds to the B&O IR codes. If you have the skills to transfer the insides of this unit to the CD5500 chassis please contact me.
Thanks,
Ben
