Latest post 05-19-2008 6:39 AM by YannChris. 3 replies.
Page 1 of 1 (4 items)
  • 05-15-2008 4:34 PM
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Beo5, PS3 and BS3
    Good evening,
    I'm about to buy a BS3-based setup.
    I also plan to use a PS3 as Blue Ray player and Media Center unit.
    My dealer told me that PS3 is present on the PUC list as a media device.
    What do I need to add to the PS3 in order to control it with my Beo5, including the remote on/off function?
    Thanks for your help,
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 05-15-2008 5:34 PM In reply to
    • Jez
    • Top 500 Contributor
    • Joined on 06-13-2007
    • Posts 150
    Re: Beo5, PS3 and BS3
    You need an IR sensor for the PS3 as it uses bluetooth for its own remote. This IR sensor plugs into the USB on the front of the PS3. I got it from the service department in Melbourne, Aust. Service called it a a "Dongle". You then run the IR blaster cable from the PS3 Dongle to the BS3.
  • 05-17-2008 3:31 PM In reply to
    • Jez
    • Posts 150
    You can also get it from Amazon online. It doesn't do the on/off function.
  • 05-19-2008 6:39 AM In reply to
    • YannChris
    • Posts 276
    Thank you Jez.
    I noticed that the BT remote works from every room of my home.
    So in a first step, it could be on/off with BT and the other fuctions with Beo5.
    Yann.
