Provided you purchase a B&O compatible lutron device it will work with all versions of BEO4
Keith..
Regards Keith....
If you are intending to purchase a Lutron Grafik Eye GBO 3000 series, you can tell if it is B&O compatible because it has the 4 coloured buttons just like the BEO4, if the buttons are all black then it will be a standard unit.
yes ive just installed lutron graffic eye for B&O after many failures of LC2s, just gave up in the end.
Worlks with my 4 year old beo 4 and a 1000 as well!
godoz
you should be OK with your beo4 with the lutron grafikeye products. be sure to order the GBO3100 range or EGBO wall stations
you can see all lutron BEO grafikeyes at http://www.onidserv.com/lutronshop/group/701/ or google lutron beo
hope this helps
nick
