Latest post 05-15-2007 5:13 PM by njbbeo. 4 replies.
Page 1 of 1 (5 items)
  • 05-07-2007 11:09 AM
    old beo4 and lutron
    hi , i am considering to buy a lutron light controller but cannot sure if it will work with my old beo4 or not . the beo4 was bought with the beocentre av5 .  any idea ?
  • 05-07-2007 12:39 PM In reply to
    Re: old beo4 and lutron
    Provided you purchase a B&O compatible lutron device it will work with all versions of BEO4
    Keith..
    Regards Keith....
  • 05-07-2007 12:47 PM In reply to
    If you are intending to purchase a Lutron Grafik Eye GBO 3000 series, you can tell if it is B&O compatible because it has the 4 coloured buttons just like the BEO4, if the buttons are all black then it will be a standard unit.
    Keith..
    Regards Keith....
  • 05-07-2007 4:15 PM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    yes ive just installed lutron graffic eye for B&O after many failures of LC2s, just gave up in the end.
    Worlks with my 4 year old beo 4 and a 1000 as well!
  • 05-15-2007 5:13 PM In reply to
    • njbbeo
    • Not Ranked
    • Joined on 05-15-2007
    • Posts 2
    godoz
    you should be OK with your beo4 with the lutron grafikeye products.  be sure to order the GBO3100 range or EGBO wall stations
    you can see all lutron BEO grafikeyes at http://www.onidserv.com/lutronshop/group/701/  or google lutron beo
     hope this helps
    nick
